Encryption ,Retention lock/WORM ,Immutability
  • July 11, 2023
  • 627 views
Forum|alt.badge.img+16
Dear All ,
i need some clarification on the below ,
we have depoloyed hyperscal x nodes and started backup activities , we would like to harden the security , we are planning to perform the following ,
1> Enabling ransdomware protection on hyperscale nodes
2> currently encryptions are not set global ddb or storage polocy ,storage pool or client side , i would like to where we is it better to enable the encrpytion
3> enabling retention lock or WORM  - best practices to achieve immutability
4> disabling root account access
since the backup operation already started to hyperscale x cluster ,above activities affect the operations ?
is there anything to be taken care before performing this ,
also do we have any evidence to show  that the backed up data are write protected and wont be able to modified
Best answer by Emils
HI @Ajal
All the additional operations are fully supported and explained in detail in our documentation. This will also outline any pre-requisites before you proceed with the steps.
For eg.
For each activity you will receive a status once the steps are completed to indicate if this was successful or not.
Emils
  • July 12, 2023
HI @Ajal
For eg.
