Epic EHR Systems
  • March 24, 2025
  • 38 views
Anyone using Epic EHR Systems for backup cache DB??? Currently I am using FS agent with Intellisnap but I am curious what are the pros/cons of Epic EHR Systems
Best answer by Jace Ross
Hi Egor,
I don’t personally use Epic EHR but the primary difference between a filesystem agent and Epic agent is application consistency. As the Epic agent interacts using Epic API calls it can quiesce the application cleanly where as Filesystem intellisnap doesn’t have the same capability.
Hopefully this helps.
  • March 25, 2025
Hi Egor,
