Error Code [62:2910]
  • Jul 28, 2023 8:16 AM UTC
  • 7 replies
  • 698 views
Forum|alt.badge.img+5
Description Error Occurred in Disk media Path.
Catalyst\\4k2NP2_01.27.2023_12.08\CV_MAGNETIC\IV_1774]-1404 OSCLT_ERR_SERVER_OFFLINE] for more info call your vendors support hotline source ****** process cvd
Best answer by Arunkumar P
i assume the storage Accelerator only needs to be installed on the media agent that connects to the storage systems.
SA is not required to be installed on the media agent.
Storage Accelerator can be setup on clients to directly send the backup data to a configured HPE Catalyst storage library. (Without the Storage Accelerator, backups send the client data to the MediaAgent first, and then the MediaAgent stores the data in the HPE Catalyst storage library.) Storage Accelerator has the following advantages:
1. Looks like a problem writing data to the disk media.
Make sure the media agent is online and has access to the data path.
2.Make sure Storage Accelerator is installed on the client. Right-click on the client computer --> View --> Installed Software.
If so, add the additional key below to your client, run a new backup to see if that helps
Category: CommServDB.Client
Type: Boolean
Value:True
Arunkumar P
Forum|alt.badge.img+9
  • Jul 28, 2023 9:03 AM UTC
Hi @backing up active directory - Looks like the job is getting failed because the MA loses the connectivity with the store once while writing the data.
OSCLT_ERR_SERVER_OFFLINE - This error comes from the storeonce so needs to be investigate from the HPE end too.
Also, run storage validation for the catalyst mount path and make sure it’s successful.
If not, I would recommend running HPE diagnostic tool from the MA to check the connectivity between the MA and catalyst store.
If the diagnostic tool also fails then please log a case with HPE.
also would have a failed disk on the storeonce also create this error
Arunkumar P
  • Jul 28, 2023 9:20 AM UTC
could this also be caused by a firewall rule blocking port 8401 and 8403
Arunkumar P
  • Aug 1, 2023 10:45 AM UTC
No, it should not cause this issue
