Error code 91:584
  • Sep 28, 2023 6:35 AM UTC
  • 141 views
Carmine Bollettino
Apprentice
Hi
I also have a problem with NETAWEBFEST machine backup (DMZ).
It gives me the error present in the screenshot.
I need some help
Best answer by Carmine Bollettino
Only Full backup works while Incremental backup does not work
Carmine Bollettino
Apprentice
Hello @Carmine Bollettino
If you check the Index Server log on the MediaAgent, what errors do you see?
Thank you,
Collin
