error getting running post backup script execution on backup
i am getting error to execute the post script running on oracle database backup. getting following error
Error Code: [7:78] ... Executable file (/opt/commvault/Base/post_scripts/db_rman_listarch_remote_vlsbi.sh ) not found in installation directory or executing outside of installation directory is disabled
however i executed the script manually on the server and it’s running fine, even the script copied on the commvault installaion directory on the /opt/commvault/Base/post_script folder.
Best answer by AMIR
the issue resolved with support. Issue was created by the command center when we added the script using the command center on the subclient  /opt/commvault/Base/post_scripts/db_rman_listarch_remote_vlsbi.sh and after that added /suppress after saving command center added “”  before and ending due to that issue created the same thing added from console no issue so updated to the engineer to double check with the engineering and report that issue.
However my issue resolved after readding the scripts from console.
  • April 2, 2026
can you post the script here or show what the top few lines look like.
  • April 2, 2026
looks like this key should help:
Key: nLimitedAdminAccess
Type: DWORD
Category:Local
Value: 0
Restart Commvault services on the client after applying the change
  • April 3, 2026
