Failed to create VSS snapshot required to run system state backup.
  • Jan 17, 2024 4:54 AM UTC
  • 1387 views
System state backup is getting failed even VSS writers are stable. server reboot and Service restart also not resolved the issue.
Failed to create VSS snapshot required to run system state backup. System state backup is skipped. VSS error [[0x80004005 2147500037] Unspecified error]. Please refer VSS Event logs for more details.
Best answer by RajA
Also, please refer this Knowledge base article for fixing this issue
Error Code [17:176] Failed to create VSS snapshot required to run system state backup. System state backup is skipped. VSS error [[0x80004005 2147500037] Unspecified error]
It could be that the volume is out of space where the shadow storage is located. If you look in the filescan.log file, you should see the snapshot attempt there for system state and be able to get more details.
Also application and system log on windows would have more info
  • Jan 18, 2024 7:13 AM UTC
Rajiv
  • Jan 18, 2024 11:24 AM UTC
Hello @Manjunatha Reddy
You can attempt to run a system state backup from the OS itself with the help of your Windows team and check if that's successful. This will also help in narrowing down the issue you are facing.
Best,
Rajiv Singal
