File System backup - Need to use accelerated feature
  • August 10, 2023
  • 48 views
Forum|alt.badge.img+5
Hello Team,
Currently File system backup using Netbackup with accelearated feature (data size is 7TB) and the full backup job is completing with in 45 Mins.
Please advise in commvault will use same accelerated feature to make it backup jobs speed.
Best answer by mikevg
Hello @Anandha K,
I think you might be looking for block level backup combined with multiple streams?
https://documentation.commvault.com/2022e/expert/18517_configuration_of_block_level_backups.html
Mike
There is no such options in Commvault, instead you need to go with Intellisnap backup
go through below link on requirement and try intellisnap on such file system
https://documentation.commvault.com/2022e/expert/62671_intellisnap_backup_system_requirements.html
  • August 10, 2023
Hello @Anandha K,
Mike
