Guidance on spinning out web server/console application out of Commserver to reduce load
  • June 27, 2024
  • 78 views
Im planning to move the web server/console out of the Commserver to reduce the load on the Commserve.  I would like to implement it in 2 sites ( active/active ) if possible to attain resiliency and high availability. This is sort of a hardware refresh with 2 additional web servers/consoles being built in 2 sites.  Hoping for some guidance on how to achieve this goal.
Thanks for any information provided
Best answer by Javier
On top of the information already provided by @HolowEd
The following documentation gives some further insights on Command Center High Availability;
https://documentation.commvault.com/2023e/essential/configure_high_availability_web_console_and_command_center.html
  • June 27, 2024
@LiliDale ,
There really isn’t much to this all you need to do is install the webserver and webconsole on the new servers and make sure that they can communicate with the commserve. The only question that really needs to be answered is are you using Private Metrics.
Edward J Holowienka.
  • June 28, 2024
