HA for AWS S3 Access nodes
  • August 21, 2023
  • 134 views
Hi All,
I have a large number of AWS S3 Buckets to protect however I have noticed that I am not able to create or use Auto scaling access nodes. Even HA for the access nodes is not an option as you can only select a single node in the config. you cannot select a group. How would I get HA for these access nodes apart from actually creating a OS Cluster to ensure HA?
i can see as per Auto-Scaling for Amazon EC2 Access Nodes (commvault.com)
that Auto-scaling is not currently supported for Amazon RDS, Redshift, DynamoDB, DocumentDB, EFS, FSx, or S3 backup. how do we ensure HA at a minimum?
This was added as part of the latest release e.g. 2023E. See: https://documentation.commvault.com/2023e/expert/153371_new_features_for_backup_agents_in_commvault_platform_release_2023e_01.html#multiple-access-node-backups-for-object-storage
Onno van den Berg
  • August 21, 2023
Many thanks for this Onno.
we are still on 2022e thats why its not working for me :)
