How do we add Mongo DB ? no option for Big Data under protect
  • April 1, 2025
  • 73 views
We wanted to test &  add Mongo DB but we are unable to locate Big Data option as the documentation here: https://documentation.commvault.com/2024e/essential/adding_mongodb_cluster.html
CV version 11:36
How do we enable the option ? What license is it supported in ? We have Evaluation License as of now.
Best answer by Jace Ross
Hi Upadhye,
I’m no MongoDB specialist but Big Data should exist. By default it may be hidden in Command Center. You can go to Manage > Customization > Navigation preferences, then select the dropdown for protect and confirm Big Data exists there and is selected for your user.
Below is what my layout looks like in my personal Commcell.
  • April 2, 2025
Hi Upadhye,
