How to address different storage targets for Oracke DB (commandline & DB subclients) and log backups ?
  • Nov 25, 2024 2:48 PM UTC
  • 62 views
Forum|alt.badge.img+13
currently I’m struggling with PLANs and Oracle Backups.
Once I associate a database subclient to a PLAN, the Archivelog storage policy is moved to the same plan. (whithout internally modifying the original PLAN association for the Archivelog subclient)
if the PLANs are using different storage targets, this is not the wanted outcome.
Is it possible to define the Archivlog policy / plan indendent to the database subclient (or even commandline) plan ? (V11.32.71)
rgds
Klaus
Best answer by Damian Andre
Hey ​@johanningk,
Unfortunately the Command Center does not seem to support what you want to achieve. The workaround you are using to use the CommCell console is the only option right now.
I’ll try to check internally if there is a plan to add this functionality to command center.
  • Dec 13, 2024 11:46 PM UTC
Hey ​@johanningk,
  • Challenger
  • Dec 16, 2024 7:57 AM UTC
Great !
Thanks Damian
