HPE Store once Catalyst replication for Airgap solution
  • December 25, 2024
  • 189 views
Hello Team,
Just want check, we have two store once devices, one is primary backup and another is secondary copy.
For secondary store once planning to configure airgap solution.
Please advise, shall we replicate one catalyst to another catalyst in two devices with out Commvault aux copy. In this case will restore data any time from secondary copy.
The secondary store once is connected another media agent server which is in different site.
  • December 25, 2024
You can make the 3rd copy come from either device. It might be beneficial to copy the data from the primary so you can copy both at once, otherwise you will have to wait until the secondary is up to date before copying to AGP
  • December 26, 2024
Hi ​@Damian Andre,
Thanks for your update.
For copying Which method will use either auxiliary copy or store once level replication for best method.
  • December 26, 2024
Hi Anand,
You can use the Auxcopy feature,
https://documentation.commvault.com/2024e/expert/support_for_hpe_storeonce_catalyst_storage.html
Note:
Auxiliary copy to another StoreOnce, tape and/or disk media is supported.
Data multiplexing is not supported and should not be enabled.
Inline Copies and Parallel copies are not supported.
Wasim
