Install SP24 search engine with SP32 Commerve
  • February 28, 2024
  • 9 replies
  • 185 views
we need a hardware refresh of search engines and there is no indexing anymore. All agents that were indexed are not active anymore. So we only have to keep the old index. The Commerve is on SP32. I tried to do all steps described here:
Search Engine Hardware Refresh (commvault.com)
The installation of the search engine (SP24 package) failed with an error:
8080  1     02/28 09:18:31 ### ### ### - Server Error:  (Error) Paket [Search Engine] is no longer supported in the current version. Please refer to the documents or contact your software provider for information on alternative options. [67109659].
I am struggling around with Commvault support, the only question I have: How to install the old search engine (SP24 package) with an SP32 Commserve? Is there an addional setting?
 Thank you.
Thomas
  • February 28, 2024
Hi @ThomasG
Search engine is deprecated on the latest version.
For similar and enhanced functionality, recommend that you upgrade existing clients to content index data using an Index Server and use the Command Center application for compliance searches.
https://documentation.commvault.com/2023e/essential/deprecation_notice_for_search_engine.html
https://documentation.commvault.com/2023e/essential/transitioning_clients_to_perform_content_indexing_using_index_server.html
  • February 28, 2024
Hello Pradeep,
I know this already. This is not possible, because there is no new agent for indexing. And my question was an other.
We need the old search engine data.
  • February 28, 2024
Hi @ThomasG
We may need to configure it has secondary instance with Sp24 media and install search engine package and register it has client with SP32
SP24 end of support is in June. So would strongly recommend you upgrade to FR32:
https://documentation.commvault.com/2024/expert/platform_release_schedule_and_lifecycles.html
  • February 28, 2024
Hi Pradeep,
we want to install the search engine on new nodes and it failed, see my first question. And would you explain what do you mean with second instance and register with SP32?
@ThomasG
You have a case for this already. The engineer is already checking with Engineering and we will get back to you.
Development has confirmed, they must not use /compliancesearch (old portal). It is deprecated.
Use command-center ->compliance-search.
  • February 28, 2024
Hello Sebastien,
Thank you, but we have to refresh the hardware of the old search engine nodes 😀 Search is working for years
Engineering can allow that. We will escalate it formally to them to look further into it.
