Intellisnap SQL
  • September 17, 2025
  • 52 views
Does anyone have a documentation of sql backup using intellisnap?
I need to use with proxy server
  1. should I configure the storage array that we are using?
  2. should I create a user when I configure the SQL subclient using intellisnap?
Best answer by Scott Reynolds
Hello ​@shay.itah
There is documentation here:
https://documentation.commvault.com/11.40/commcell-console/sql_server_agent_intellisnap_configuration.html
https://documentation.commvault.com/11.40/commcell-console/intellisnap_best_practices_sql_server_agent.html
To answer your direct questions
  1. should I configure the storage array that we are using?  - Yes setup of the array is required
  2. should I create a user when I configure the SQL subclient using intellisnap? - A user for backups I assume? -Yes a SQL account can be leveraged same as streaming
Hello ​@shay.itah
