Issue installing backup agent Debian 12
  • September 20, 2024
  • 165 views
I have the following issue:
-OS was upgraded from debian 9 to debian 12
​​​​​​​-backup services not starting anymore since then
-uninstalled and reinstalled locally interactive 32.49, but the backup agent is being stuck forever on Starting Services phase
-downloaded new interactive fresh pkg 32.59, but the same issue
-i cannot find too much in the logs
-tried to start services manually, but only cvfwd started, while the other services not (no error displayed):
/opt/commvault/Base/svc_ctrl -focus Instance001 -start cvd
/opt/commvault/Base/svc_ctrl -focus Instance001 -start cvlaunchd
/opt/commvault/Base/svc_ctrl -focus Instance001 -start ClMgrS
/opt/commvault/Base/svc_ctrl -focus Instance001 -start cvfwd​​​​​​​
-verified before if there is anything else listening on CVD and CVFWD (CVD is using default 8400 port, CVFWD 8600) + checked and manually deleted leftover folders if any: Commvault Installation folder; Log folder; Registry folder + checked for orphaned commvault processes
Any idea what can i check more?
Best answer by mihaib200
The root cause of this was because another software (Dynatrace monitoring software) interfering with the the commvault backup services. There is a feature on the Dynatrace called "auto-injection” that caused this. Commvault support helped to find the root cause.
I can see this, but I understood from Linux team that selinux is not used (disabled):
629809 140357155067776 09/20 10:16:10 ###  cvInstallUserName = [root]
629809 140357155067776 09/20 10:16:10 ###  selinux_context_applied before:None
629809 140357155067776 09/20 10:16:10 ###  constants.NEW_INSTANCE:True constants.is_linux:True constants.UPGRADE_TYPE:0
629809 140357155067776 09/20 10:16:10 ###  Executing: getenforce [GALAXY_INST=Instance001]
629809 140357155067776 09/20 10:16:10 ###  output = /bin/sh: 1: getenforce: not found
, retcode = 127
629809 140357155067776 09/20 10:16:10 ###  getenforce command failed
629809 140357155067776 09/20 10:16:10 ###  Setting permissions . . . finished.
629809 140357155067776 09/20 10:16:10 ###  Starting services . . . started.
629809 140357155067776 09/20 10:16:10 ###  Starting services as user root
629809 140357155067776 09/20 10:16:10 ###  LD_LIBRARY_PATH = /opt/commvault/Base:/root/.gxsetup/cvpkgadd
629809 140357155067776 09/20 10:16:10 ###  Executing: /opt/commvault/Base/Galaxy -instance Instance001 start [GALAXY_INST=Instance001]
cvd.log should show something interesting and potentially messages/syslog
  • January 14, 2026
