Kubernetes Openshift Backup volume backup issue
Forum|alt.badge.img+8
  • Byte
  • 29 replies
Hello All,
I am getting many warning errrors during RED hat openshift backup. I see the following warning on the events . Will be mounting live volume [] to worker pod [] since it does not support volume snapshots.  How to ignore this error?
Best answer by Sureshkumar S
Hi ​@ETO ,
Good day!
By default CV will try to protect the application with snapshot method. If the volume doesnt support snapshot backup we will switch back to live mount method.
This is to alert user that the snapshot method is not used for protecting the affected PVC
Ref : https://documentation.commvault.com/2023e/essential/backup_process_for_kubernetes.html
 Is there any reason why you want to suppress this ?
Sureshkumar S
Hi ​@ETO ,
Good day!
Sureshkumar S
  • Byte
  • 29 replies
  • March 26, 2025
Hello ​@Sureshkumar S
Is it possible to exclude these?I guess these are effecting backup performance am I right?
Hi ​@ETO ,
Exclude the events ? This should affect performance.
Are you referring to stopping the backups being fallback to live mounting method of backup ?
Sureshkumar S
downhill
Byte
Forum|alt.badge.img+9
  • Byte
  • 68 replies
  • April 3, 2025
I have the same exact issue and even enabling the setting per app group doesn’t quiet the alerts. it’s been driving us nuts for weeks.
AFAIK you(Commvault) can’t do snapshots of bare metal OpenShift and we don’t need to know this.
If there IS a documented way to do snapshots when the “storage” is all native OpenShift, I haven’t seen it.
Otherwise a regkey to mute the events please.
thanks
Cookie policy
Cookie settings
