Listing Privacy disabled Clients
  • Dec 30, 2024 6:57 AM UTC
  • 79 views
Forum|alt.badge.img+9
Hello All,
I need a report or a qoepertion command to list of which edge clients privacy is disabled. I have searched on documentation but I couldnt find a command.
Best answer by Pradeep
Hi ​@ETO
kindly refer below document and run command line qoperation execscript -sn GetAllLockedClientsAndOwners to get list of private clients
https://documentation.commvault.com/2024e/expert/listing_all_private_clients.html
We are also working on reports in upcoming release to add this section under end point clients.
  • Jan 1, 2025 3:37 AM UTC
Hi ​@ETO
  • Jan 1, 2025 3:58 PM UTC
Hello ​@Pradeep
Thanks for the link. well, İs it possible to list privacy disabled clients?
  • Jan 2, 2025 2:01 AM UTC
Hi ​@ETO
Yes kindly execute the command to get the output
You can list all clients where the Prevent administrators from viewing or downloading your data check box is selected. The client name and the user names and email addresses of the associated client owners are displayed.
  • Jan 2, 2025 5:54 AM UTC
Hi ​@Pradeep
Thanks for answers. As I understand we can just list clinets of Privacy Enabled. It is not possible to list clients only PRIVACY DISABLED, am I right ?
  • Jan 2, 2025 6:18 AM UTC
Hi ​@ETO
Currently, there is no qcommand available to directly list clients with the privacy-disabled option. However, you can run the q list -c > c:\clients.txt command to export all clients to an Excel file. From there, filter the clients with privacy enabled and remove duplicates to identify the required entries.
