MA+VSA proxy installation in docker
  • Nov 4, 2024 8:20 AM UTC
  • 76 views
Forum|alt.badge.img+8
Is it possible to install MA+VSA proxy as a docker container ?
Has anybody any example of /opt/cvdocker.env?
Lubos
Best answer by Damian Andre
Hi @Lubos Dvorak
I dont have an example of docker but these components can be installed in kubernetes using helm chart. So maybe you can look at the helm chart output and create an equivalent docker deployment?
https://documentation.commvault.com/2023e/essential/installing_commvault_packages_in_kubernetes_using_helm.html
Since live browse is not supported, I don’t think VSA is a good fit for containerization in most setups
Forum|alt.badge.img+9
Hi @Lubos Dvorak
  • Nov 4, 2024 10:40 PM UTC
Hi @Lubos Dvorak
