Manual Upgrade of Visual Studio Tools for Applications
  • April 14, 2026
  • 129 views
Hi.
Is there a supported way to manually upgrade Visual Studio Tools for Applications? I do not see any mention made of it.
Current release is 16.0.31110
Our customer advised that CVE-2025-29803 was detected in the current release. An upgrade should be done to version 16.0.35907.
Current Commvault release is 11.40.42.
I also don’t see any mention made in the Commvault maintenance release for this version.
Any advise?
Thanks.
Best answer by Pradeep
Hi ​@Iggy ,
Commvault Systems does not utilize VSTA; therefore, this vulnerability can be disregarded from a Commvault perspective.
  • April 15, 2026
Hi ​@Iggy ,
