Media marked as appendable automatically not reuse after appendable
  • February 18, 2024
  • 131 views
Hi Team,
We have facing issue in our commvault infra. While running auxillary copy job media marked as appendable its not full , after appendable is not reusable
This appendable media is not full, also tape is getting stuck inside the drive,
if we can reuse this appendable tape without erase the existing data(because we data retention in 5 years)
please share any solution for this issue
Hello @Adarsh.op
I can see you have raised 4 separate questions for the same topic.
To save you the admin work i will get all but the following closed off.
KInd regards
Albert Williams
Hello @Adarsh.op
KInd regards
Albert Williams
Correction: This is the link to the active thread:
