Migration Plan
  • January 2, 2026
  • 59 views
Hi everyone,
I am currently performing a hardware refresh/migration from a legacy Media Agent to a new Commvault HyperScale Edge (Single Node).
Current Setup:
  • CommServe is on a separate dedicated server.
  • Legacy MA: Windows Server with local disk libraries (NTFS).
New Setup:
  • HyperScale Edge (Single Node).
  • Already joined to the CommCell, and the HyperScale Storage Pool is created.
Proposed Migration Plan: Since I cannot simply move the DDB/Disk (due to the architecture change to HS Storage Pool), I plan to do a Side-by-Side migration:
  1. Create a Secondary Copy on the existing Storage Policies.
  2. Set the Target Library as the new HyperScale Storage Pool.
  3. Run Auxiliary Copy to sync all data.
  4. Once synced, Promote the Secondary Copy to Primary.
  5. Decommission the old MA.
My Questions:
  1. Is this the recommended workflow for migrating to HyperScale?
  2. When creating the Secondary Copy, should I expect any specific behavior regarding the DDB association, since the target is a Storage Pool?
  3. Are there any specific "gotchas" or performance settings I should be aware of during the Aux Copy phase (e.g., Scalable Resource Allocation)?
Thanks in advance!
Best answer by Scott Moseman
Your proposed plan is the perfect way to migrate to new MAs/Storage.
Scott
Scott Moseman
Forum|alt.badge.img+23
  • January 2, 2026
Scott
