Monitoring job streams
  • October 5, 2023
  • 143 views
Is there any way to poll/monitor the number of currently active Job Streams via CLI/API?
We can see that value in the bottom part of the CommCell browser but I couldn’t find in the technical documentation any way to collect that value through some automated mechanism.
Thank you!
Hello @Alessandro
I do not believe this is possible “out of the box” and I have not seen it done before, but it might be something our Professional Services Team could help you with.
May I ask what is the purpose of monitoring the number of streams through CLI\API?
Thank you,
Collin
  • October 5, 2023
Hi Collin,
Thank you for the fast answer!
We need to setup a monitor of the active streams because we had several incidents in the past days with jobs failed due to the max number of allocated job streams reached.
We need to setup a method to register the number of active jobs to alert in case the max number is reached and to see if there is an increasing trend.
Hello @Alessandro
Fair enough. Like I said I don’t believe this is possible out of the box, but Professional Services may be able to create custom reports for you. You can get in touch with Professional Services through your Account Manager.
Thank you,
Collin
  • October 9, 2023
I opened a ticket to support.
It looks there is no monitor/report for that.
No CLI/API either...
Hello @Alessandro
Sorry to hear that. I would reach out to your Account Manager to see if this is something Professional Services can do. They have the ability to create custom reports.
Thank you,
Collin
