Multi person authorization - Restore request
ApK
Explorer
Forum|alt.badge.img+8
Hi All
I have enabled the Multi person authorization - Restore request.
The users I have in my environment only have very few permissions, only able to do backup and restores.
Now that the above have been enabled, my users don’t see the request in the job controller in the Java Console even though I have placed them in the “User groups which can authorize the request”.
If I look in the documentation under Multi person authorization - FAQ it states:
3. Do users need special permissions to be an approver to authorize requests?
No, users do not need any specific permissions to approve a request. Instead, they must belong to the user group configured as the approver group.
FAQ for Multi-Person Authorization
But still its not working, as the users cannot see the request. What am I missing, I guess some permissions anyway?
Regards
-Anders
Best answer by ApK
It might be because we are using the “CV_Restricted_Visibility” to limit what a user can see in the Java Console:
The CV_Restricted_Visibility user group must be created to hide CommCell elements from selected users. When assigned to this user group, members can see only a portion of all available options in the CommCell. The following elements are excluded from the restricted view of the CommCell Console:
  • Tools menu
  • Toolbar buttons including Alert, Scheduler, Control Panel, and Web Console
  • CommCell Browser nodes including Security, Storage Resources, Policies, Content Director, and Workflows
Forum|alt.badge.img+9
The configuration change on the workflow itself needs dual authorization before it takes effect. Was that done? Did you set it to a group or individual users?
ApK
Explorer
  • July 6, 2026
Hi Amey.
Yes the configuration change has been approved, and I can see the authorization job in the job controller, but I am also part of the master role.  Everything is setup in the work flow as supposed and using groups, but the user cannot see the authorization job in the job controller.
are they able to see the approval requests in the command center?
ApK
Explorer
  • July 6, 2026
They don’t have access to the CommandCenter, so can’t test that.
Erase4ndReuseMedia
Do they see the request via the CommCell Browser > Workflows > Interactions?
ApK
Explorer
  • July 7, 2026
  • Tools menu
