Nutanix AHV quiesce
Hi All,
i would like to ask regarding Nutanix AHV quiesce Problems.
did we need extra firewall ports from the vm guest tools outside. So the vsa proxy need TCP Port 9440  to running backups. For quiesce the guest tools is there any more firewall port needed ?
Best answer by Jace Ross
Hi SSchmidt,
No additional firewall ports are required for quiescing as that is part of snapshot creation.
When AHV requests the snapshot of the VM it will see the quiesce request and use integration tools to communicate with the guest OS to handle the quiesce operation. The snapshot will then run against the quiesced OS and Commvault will proceed with a backup of the quiesced volumes.
In short, quiescing is all between the AHV and the guest OS, no networking is required.
  • August 26, 2026
Hi SSchmidt,
  • Certified Expert
  • August 26, 2026
Hi
i our case was the “problem” that the ngt tools are installed but not enabeld. So in nutanix there are 2 steps needed. Under vmware its enough to get the tools installed.
