Old Exchange DB from tape
  • November 9, 2023
  • 57 views
Have an old Exchange backup on tape from an old Commvault which we no longer have, I can restore Server backups using mediaexplorer tool and I can see the Exchange DB backups on there but the restore option is greyed out on the exchange DBs
Is it possible to restore the exchange DBs from an old tape using the MediaExplorer tool ?
Thanks for any help.
J
Hello @JAdams
Media Explorer is only supported for DR backups and noted here:
https://documentation.commvault.com/v11/expert/43562_retrieving_disaster_recovery_dr_backups_from_tape_or_disk_storage_using_media_explorer.html
If this is an old backup that has just been aged, you may be able to recover it using following method
https://documentation.commvault.com/2023e/expert/12007_recovering_aged_data_advanced.html
