Oracle Archive Log subclient not running on schedule
Has anyone experienced issues with the schedule for the ArchiveLog_standby subclient not running on schedule even though it is assigned to a Plan?
From what we can see is that this behaviour occurs when database maintenance occurred. There are no failures logged, it just does not run.
To resolve it you temporarily change the backup plan to something else and revert, which “enables” the backup again.
Cheers.
Best answer by ddwyer
Hi Ignes,
Hotfix number is 2082:
Oracle archive log backups may fail to trigger automatically in a corner case.
2082
Regards
David,
  • May 5, 2026
Hi Iggy,
Can you confirm the version and maintenance release of Commvault you're currently running?
There was an edge condition identified and released in February and March of this year for version 11.36, 11.40 and 11.42
Innovation Update Release 11.42.70 (Feb 13, 2026)
If you are on the latest update pack for one of these versions, please make sure that the Commserve and clients are all updated and running the same maintenance release.
David
  • May 6, 2026
Hi David.
The current version is 11.36.68.
An upgrade is planned to 11.40.38.
Cheers.
Ignes
  • May 6, 2026
Hi Ignes,
Thanks for confirming, unfortunately 11.40.38 does not include the specific hotfix for the Oracle archive log backup schedule issue as it’s part of 11.40.40.
Can you upgrade to 11.40.42 instead? This maintenance release includes the hotfix.
David
  • May 7, 2026
Hi David.
Do yo have the hotfix number for this?
I have changed the upgrade plan to MR42 instead.
Thanks.
Ignes
  • May 7, 2026
Hi Ignes,
2082
Regards
David,
  • May 7, 2026
Thanks so much!
Cheers.
