Orcale DB nonarchive mode
  • August 16, 2023
  • 862 views
Forum|alt.badge.img+16
“”Error while backing up Oracle Database. Error Details [Online backup cannot be run while database is in NOARCHIVELOG mode.]
i know that online backup is not possible if db ins nonarchive mode, what is procedure for offline backup , can commvault perfrom this
what if we turn off non archive mode for initial backup and turn it on again
Best answer by Karthikeyan K
Hi Ajai,
If you wanted to take offline backup, then the DB should be in mount state.
Please find the below BOL,
https://documentation.commvault.com/2023e/expert/20215_configuring_oracle_subclients_for_offline_backups.html?_gl=1*cugujv*_gcl_au*MjA1OTU0MzY0OC4xNjkwMjE2NTM2
Lights out script will automatically bring down the DB and brings up once the backup completes.
Note: During offline backups, no user or application cannot access the DB.
Karthikeyan K
Sunil
  • August 16, 2023
Hi @Ajal
You can schedule offline backup by selecting offline mode. This will also have Lights out option which automatically brings down the database before the backup starts and brings it up again after backup completes.
If you happen to turn off NOARCHIVELOG mode in the future, you will have to schedule online backups and decide whether to continue doing offline backups or not.
Sunil-
  • August 17, 2023
Hi Ajai,
Karthikeyan K
