Override restrictions from Plan
antonio
Byte
Forum|alt.badge.img+8
Hello, everyone.
Just a simple question about Override restrictions option in Plan: after enabling the option “Allow plan to be overridden” is there any way to disable it? If possible, how can this be undone?
Thanks.
Best answer by dude
“If you select the Allow plan to be overridden toggle key, and then click Save, you cannot disable the key.”
Refer to: https://documentation.commvault.com/2023e/essential/modifying_server_plan.html
dude
Byte
  • Byte
  • 287 replies
  • June 22, 2024
antonio
Byte
  • Byte
  • 50 replies
  • June 25, 2024
Thank you @dude, this went unnoticed by me, 😅.
Cookie policy
Cookie settings
