Override restrictions from Plan
  • Jun 21, 2024 8:59 PM UTC
  • 71 views
antonio
Apprentice
Hello, everyone.
Just a simple question about Override restrictions option in Plan: after enabling the option “Allow plan to be overridden” is there any way to disable it? If possible, how can this be undone?
Thanks.
Best answer by dude
“If you select the Allow plan to be overridden toggle key, and then click Save, you cannot disable the key.”
Refer to: https://documentation.commvault.com/2023e/essential/modifying_server_plan.html
dude
Forum|alt.badge.img+20
  • Community All Star
  • Jun 22, 2024 4:00 PM UTC
antonio
Apprentice
  • Jun 25, 2024 5:17 PM UTC
Thank you @dude, this went unnoticed by me, 😅.
