Package creator
  • Aug 24, 2023 6:47 AM UTC
  • 232 views
Forum|alt.badge.img+16
i am trying to create package for laptop by following the below link
but am not able to find the option
  1. Go to the Cloud Services website.
  2. On the top of the page, click menu150804.png > PACKAGE CREATOR.
    The Package configuration page appears.
https://documentation.commvault.com/2022e/essential/86810_creating_end_user_laptop_package.html
Best answer by Nutan Pawar G
Hi @Ajal
Do you see this option from your side?
Hi @Ajal
  • Aug 24, 2023 7:20 AM UTC
@Nutan Pawar G  it was directly taking me to cloud console page and was struggling , thanks
if you can help me , we are implementing laptop backup with network gaeway
could you help me with port number
client to network gateway
network gateway to commsrv /MA/Storage
@Ajal
For your reference:
https://documentation.commvault.com/2022e/expert/7102_port_requirements_for_commvault.html
Required Network Ports
Target Machine to Access
Target Ports
Accessed From
Feature or Purpose
All
8400 (Default CVD port) (configurable)
All other network peers
Required to be open on MediaAgents for faster data traffic
All
8403 (configurable)
All data and control traffic
CommServe server
8401
CommCell Console
Administering product using CommCell Console
Rajiv
  • Aug 24, 2023 7:34 AM UTC
@Ajal
More information on configuration of firewall can be found here:
https://documentation.commvault.com/2023e/expert/41208_firewall_configuration_for_laptop_backup.html
Best,
Rajiv Singal
  • Aug 24, 2023 7:37 AM UTC
@Rajiv @Nutan Pawar G  thanks guys ,
i am bit confused , the port need to be open from client to gateway right
then gateway to commserv
