Plans and separation of incremental backups
  • April 16, 2025
  • 83 views
HI together,
we are currently using a storage-policy that has an incremental storage-policy attached (for the incremental backups).
When we created a plan this kind of setup is no longer possible via Command Center … but it was possible to attach a different (base) plan for the incremental backups via the Commcell Console. (11.32 and 11.36).
Is this only working because we are on the lucky side … or is this intended? Is there any ”plan” to attach incremental “plans” via Command Center?
Best regards.
Michael
Best answer by Pradeep
Hi ​@Michael Seickert ,
As of now we don't see an option to modify or disable the incremental schedule directly within the plan.
Incremental backups are automatically configured based on the RPO defined in the plan.
  • April 17, 2025
