Psudomount for vmware restore
  • July 11, 2023
  • 250 views
I have an issue that all browse for vmware VMs are failed - with error - “live browse enumeration failed”
I can see that there is a mount in the MA folder for mounts (\installfolder\pseudomount\persistent\pseudodevices\
I try to reboot the cmmvault services on the MA and also to reboot the server - the mount does not get released
can I manually delete it?
Best regards
Best answer by Sebastien Merluzzi
You should see two folders:
one showing the disks \pseudomount\persistent
and the other one the files/folders \pseudomount\transient
Yes if nothing is running you can delete it.
HI @LiorRN
Can you kill the Persistent Recovery job in Job Controller.
If you do not see the job, add the following key on the Commserver:
https://documentation.commvault.com/additionalsetting/details?name=%22ShowPersistentRecoveryJobsForVSA%22&id=6726
Then wait sometime and check again.
Sebastien
  • July 11, 2023
Thanks for the quick replay,
I killed the Persistent Recovery job -  the mount is still there
  • July 11, 2023
Can I manually delete this folder in \installfolder\pseudomount\persistent\pseudodevices ?
