Purestorag // Purity CloudSnap
  • February 21, 2024
  • 115 views
Hello all,
just one quick question.
Is the feature “cloudsnap” from purestore, to offload snapshots from the prod system to an “cloud” (S3) target supported by commvault as an aux-copy//snap-copy?
https://blog.purestorage.com/products/purity-cloudsnap-delivering-native-public-cloud-integration/
Kind regards
Julian
Best answer by Collin Harper
Hello @skoomer
We currently do not support CloudSnap, but Development is looking into getting it coded and supported. At this time there is no ETA on when it could be supported.
Thank you,
Collin
  • February 21, 2024
Hello @skoomer
Thank you,
Collin
