Query on Fresh install or Updating Commvault software using MECM
  • November 7, 2025
  • 29 views
Has anyone use MECM (Microsoft Endpoint Configuration Manager) software to deploy or update Commvault software in the entire Commcell environment?  We are currently exploring this option but I dont have much information to begin exploring. Also I am not sure if this will even work or is supported by Commvault
Any advice or suggestion is highly appreciated
Best answer by Pradeep
Hi ​@LiliDale ,
You can use MECM to distribute and install Commvault client software on Windows endpoints or servers.
This approach is often used in large environments to simplify mass deployment.
  1. Download the Commvault agent package or create custom installer from CommServe).
  2. Add it as an Application or Package in MECM.
  3. Configure deployment settings (install command, detection method, etc.):
  • November 8, 2025
Hi ​@LiliDale ,
