Question about Storage
  • November 18, 2023
  • 213 views
Forum|alt.badge.img+2
During configuring a SAN data server, Is we have an operating system that is required for media agent hosting disk libraries? Should it be Linux, or it be Unix or Windows?
Best answer by dude
The following MediaAgents are supported:
  • Windows
    MediaAgents on windows clusters are not supported with Shared SAN Data Servers.
  • Linux
  • AIX
dude
Forum|alt.badge.img+20
  • Community All Star
  • November 19, 2023
I`m not sure what exactly your question is but you can refer to the SAN Data Server direct link here;
https://documentation.commvault.com/2023e/expert/9562_shared_san_data_server.html
  • November 19, 2023
@dude thanks, for reply, From DOC “Since the shared SAN data server is a Linux based file server which can be accessed through Fibre channel interconnect,”
So that we can use any OS for media agent they will host disk library, or it is recommended to be Linux only ?
dude
  • November 19, 2023
  • Windows
  • Linux
  • AIX
  • November 19, 2023
Thanks @dude ,
