Removing failover instance
  • Aug 20, 2024 10:11 AM UTC
  • 281 views
Hi dears,
i had old configuration of live sync but the engineer has deleted the CS DR,
when i deployed new Standby node but during the live sync configuration i have found that old standby node still visible in livesync wizard and a wrong info is exsit regarding primary and passive nodes
based on troubleshooting and search i have found that there ares the below scripts to remove and cleanup the failover instances but i cannot find/download the scripts.
can someone assist by providing a link to download the below scripts?
RemoveFailoverInstanceClientProp
CleanupStaleFailoverAssoc
thanks in advance.
Hello @Mansour_Nour
In regards to the two scripts i can see support has given the script out in the past for “RemoveFailoverInstanceClientProp” without going to Dev but script “CleanupStaleFailoverAssoc” is always one that comes from Dev.
With this in mind i recommend raising a support ticket and they can provide you any scripts and guide you.
Kind regards
Albert Williams
Hello @Mansour_Nour
Kind regards
Albert Williams
