Replace tape library
  • May 13, 2024
  • 533 views
I am about to replace our old tape library with some new hardware and was wanting to know the steps to follow.
I can add the new tape library to the Commcell, but when do i configure the new library with the existing storage policies? After i de-configure the old library and move the orphaned media to the new library?
Best answer by Collin Harper
Hello @JohnC
It shouldn’t matter if you update the policies before or after you de-configure the tape library.
Deconfiguring a Tape Libraryhttps://documentation.commvault.com/2023e/expert/deconfiguring_tape_library.html
  • If there is no assigned media, the library will be deconfigured and deleted.
  • If there is assigned media, the library will be marked deconfigured.
  • After it is marked deconfigured, right-click the library and click Delete to delete the library.
  • The assigned media will be available under Orphaned Media after the tape library is deleted.
Move Orphaned Media to Libraryhttps://documentation.commvault.com/2023e/expert/orphaned_media.html#move-media-to-library
Thank you,
Collin
Hello @JohnC
Thank you,
Collin
  • May 13, 2024
@Collin Harper - Thanks for the reply, much appreciated.
