Replication CDR
  • Dec 20, 2023 11:50 AM UTC
  • 71 views
is it possible to replicate data (files and directories) on volumes larger than 64 TB (Windows)?
VSS has a limitation of 64TB volumes. Can I disable usage of VSS for replication?
Lukasz
Best answer by Damian Andre
Unfortunately not - CDR requires VSS and there is no way to bypass.
You may want to consider using file system replication:
https://documentation.commvault.com/2023e/expert/replication_for_file_system_agents.html
This replicates data captured from backup, for which you can disable VSS.
  • Jan 8, 2024 4:40 AM UTC
