reply/forward from web console
  • Jan 22, 2024 1:26 PM UTC
  • 143 views
Forum|alt.badge.img+2
anyone has experience about reply/forward email exchange that has been archived from web console ?
environment exchange on prem
Best answer by Chris Hollis
@Tyo
Looks like the options are hidden by default for some reason. I’ll get confirmation.
In the meantime, could you please add the following additional setting to your Commserve Client properties then re-try?
https://documentation.commvault.com/additionalsetting/details?name=%22bshowExchWebServerFields%22&id=10564
I tested this and it worked:
You need to then restart the JAVA console for it to be visible.
Chris
Chris Hollis
Hi @Tyo
You need to setup this feature, instructions are here: https://documentation.commvault.com/2023e/expert/setting_up_message_reply_01.html
Note:
Support
  • Message reply is supported for Microsoft Exchange 2007 or later.
  • Message reply is not supported for Office 365 with Exchange.
Any questions please let me know.
​​​​​​​Regards,
Chris
  • Jan 23, 2024 1:50 AM UTC
Hello Chriss,
thanks for information, actually i already did those step,, but i stuck on this parts :
i cant find how to enable email reply/forward on there ?
can you help me to suggest where i can found  that setup ?
Chris Hollis
@Tyo
As in, the option ‘Enable Email Reply/Forward’ is not visible to you on the web server client properties?
Chris
  • Jan 23, 2024 2:07 AM UTC
yup,, we cant see that option on client properties .. so there’s no action can be done  actually
Chris Hollis
  • Jan 23, 2024 10:44 PM UTC
@Tyo
Chris
