Resillency- Disperse Factor
  • August 1, 2023
  • 133 views
could someone explain me how the below options are working ,
if i have 6 nodes for a storage pool , what if i have more than 6 nodes ,
what is the disperse factor mentioned here
R Anwar
  • August 2, 2023
Hi @Ajal
For HyperScaleX, we have metadata nodes which are generally the first three nodes for deployment. Irrespective of how big the cluster is, only one node failure can be tolerated.
You can run the command /usr/local/hedvig/scripts/showmembers.exp to find the metadata nodes. It will show port 7010 for the nodes. Nodes that show only 7000 are not running metdata service.
hedvigduro> showmembers
xxx.prod:7000
xxx.prod:7010
yyy.prod:7010
yyy.prod:7000
zzz.prod:7010
zzz.prod:7000
The EC code will be 4+2, even if you have more than 6 nodes.
  • August 3, 2023
@R Anwar  then what is the point of giving option to select standard medium or high,
which one to select ?
R Anwar
  • August 3, 2023
Hi @Ajal
I reconfirmed and 3 nodes with have EC 4+2 and 6 nodes and above will have resiliency of 8+4 giving higher tolerance level.
  • August 3, 2023
@R Anwar thanks for the update
could you tell me what is meant by disperse factor here also if i choose high the usable capacity will be less?
Rajiv
  • August 8, 2023
Hello @Ajal
Please refer to get an understanding on the terminologies : https://documentation.commvault.com/2023e/expert/9092_hyperscale_reference_architecture_terminology.html
Best,
Rajiv Singal
