Restore Out-Place Possible Bug 11.32.38
  • Mar 15, 2024 1:06 PM UTC
  • 150 views
EJIE
Apprentice
Forum|alt.badge.img+5
Hello folks,
I have a role with permissions to perform certain operations for platform users. In this role, only the restore "In Place Recover" and "In Place Full Machine Recovey" of the VM is allowed, but when updating to version 11.32.38 .
In the command center, when restoring a VM, I get the "Out Place" option, which should not appear because I do not have those permissions; in the previous version 11.28.68 it did not appear as it should.
Regards.
Best answer by EJIE
Hi @Siva Kumar Tirupathi
Yes, the CMR request are: Case 240318-191
Thank you.
Regards.
Forum|alt.badge.img+2
Hi @EJIE
I have tried this in lab 11.28 with a user having inplace recover, inplace full vm restore permission and I can see Out of place option in restore screen.
Can you please create a CMR to address this in future releases ?
Siva
EJIE
Apprentice
  • Mar 18, 2024 7:32 AM UTC
Yes, I´m going to create a CMR for fix it in the futures releases.
Thank you,
Regards.
Hi @EJIE
Did you create CMR? please share CMR#.
Siva
EJIE
Apprentice
  • Mar 21, 2024 9:41 AM UTC
Thank you.
Regards.
