SAP for oracle Brrestore failed because of segfault issue
  • Jul 4, 2023 7:39 AM UTC
  • 270 views
2023-07-04T02:01:45.304060-04:00 servername kernel: [1631379.901772] brrestore[16118]: segfault at 0 ip 00007f25f6909757 sp 00007ffd5db61298 error 4 in libc-2.22.so[7f25f686d000+19b000]
2023-07-04T02:01:45.304441-04:00 servername systemd-coredump[16178]: AT_NULL terminator not found, cannot parse auxv structure.
2023-07-04T02:02:35.956069-04:00 servername kernel: [1631430.549862] brrestore[16462]: segfault at 0 ip 00007f5cdfddc757 sp 00007ffed969f428 error 4 in libc-2.22.so[7f5cdfd40000+19b000]
2023-07-04T02:02:35.962341-04:00 servername systemd-coredump[16959]: AT_NULL terminator not found, cannot parse auxv structure.
2023-07-04T02:05:06.732062-04:00 servername kernel: [1631581.312128] brrestore[17123]: segfault at 0 ip 00007f69d4fc1757 sp 00007ffd1f7057c8 error 4 in libc-2.22.so[7f69d4f25000+19b000]
Best answer by Gowri Shankar
Hi @Rahul Shinde
Whats the version of Commvault and BRTools in use?
Please ensure the recommended brtools version + patch level are in place
Docs link → https://documentation.commvault.com/2022e/expert/3086_sap_oracle_agent_system_requirements_03.html
Ensure the permissions are good, use oracle group for commvault install, if the group is not used try running cvpkgchg -g <group name> -p 775 and rerun the restore
In case if the issue still persists then open a support incident and once of us could review.
Gowri Shankar
MichaelCapon
Hello @Rahul Shinde,
Since we’re getting a seg fault here, I’d suggest opening up a case with support so that the team can check this further for you. - We’ll need the logs from this client and any core dumps (if present).
Michael
  • Jul 4, 2023 8:53 AM UTC
Thanks Michael. I will troubleshoot more and if not found solution, then I will raise the case with Commvault support team.
Forum|alt.badge.img+16
Hi @Rahul Shinde
Gowri Shankar
  • Jul 12, 2023 10:05 AM UTC
Hi rahul, did you manage to restoe the DB ? We are facing the same exact problem...
