SAP HANA system replication
  • Oct 4, 2023 7:41 AM UTC
  • 296 views
Hi Vaulters,
Regarding SAP HANA, we’ve got two sites, first one being replicating its SAP HANA to the second (using HANA replication).
With commvault, how can we manage this type of scenario ? Do we only need to back up data in the first site, or do we need to implement another MA on the second site to back up the replicated data also ? It's more of a design concern.
Any provided suggestion would be appreciated.
Regards.
Best answer by Sunil
Hi @Commvault Engineer
If you are not worried about your DB failing over to the secondary node and don’t need to run backups on the second, you can simply backup on the first node.
However, if your DB is designed to be failed over to the secondary(either planned or unplanned), and you don’t want the backups to be interrupted when a failover occurs, you would need to configure replication aware instance as it’s documented below.
https://documentation.commvault.com/2023e/expert/22355_configuring_sap_hana_system_replication.html
And if your primary and secondary are in different physical locations and need to use different MA and storage for backups, you can also configure the Region based backups using the below procedure.
https://documentation.commvault.com/2023e/expert/136824_using_region_based_backups_for_sap_hana_system_replication.html
Sunil
Sunil
Forum|alt.badge.img+16
  • Oct 4, 2023 11:46 AM UTC
Sunil
Sunil
 Thanks a lot @Sunil for your prompt feedback.
Sunil
  • Oct 17, 2023 2:40 PM UTC
Sunil
Glad I could be of help. Cheers!
