Scheduled report create Dated Folder
  • Oct 19, 2023 12:57 PM UTC
  • 97 views
Heath
Apprentice
I have created some new reports and I found out that you can add cvdate to the end of the file name and it adds the date time, wish it only added date but that is fine.  What I want to know, can Commvault created a current dated directory to put this in?  Right now It goes to a base folder and I have to go create the dated folders.  We need this for Audit purposes and just trying to streamline it even more so I can be out and not have to deal with doing a bunch of folders when I get back from vacation.  Maybe I have to use a 3rd party way, but hoping Commvault can do it.
Best answer by Collin Harper
Hello @Heath
At this time its currently not possible to output a report to a different folder each time based on date.
It may be possible to change the default location but not possible to change the output folder automatically based on Calendar Date.
Thank you,
Collin
Hello @Heath
Thank you,
Collin
Heath
Apprentice
  • Oct 20, 2023 1:18 PM UTC
Thank you @Collin Harper Not the answer I really wanted but the answer I kind of figured at this time.
