Scripts for Application Validation - Antivirus
  • October 20, 2023
  • 224 views
PedroRocha
Explorer
Hello!
I know we can run scripts to validate applications (when using Application Validations for VMware VMs).
Commvault has a few ready to use scripts (Oracle, SQL Server, MS Defender).
Has anyone customized this MS Defender script to use another AV engine (like ESET, Symantec, Kaspersky, Trend Micro)?
I heard that Veeam has a feature called Surebackup which kind of comes ready to use (checkbox) a few AVs instead of having to create custom scripts.
Pedro
Good day @PedroRocha,
I apologize for the delay in responding to your query. We are currently in the process of arranging an engineering review for your question. Please rest assured that we are working diligently to provide you with a detailed response as soon as possible.
Thank you for your patience and understanding.
  • November 7, 2023
Apart from documented SQL, Oracle, and MS defender scripts, we don’t have default scripts for other AVs. As you are aware build and use own scripts in custom scripts validation. May be CCR required here to add any new scripts i think.
https://documentation.commvault.com/2023e/essential/128059_scripts_for_application_validation.html
https://documentation.commvault.com/2023e/essential/128049_enabling_validation_for_vm_group.html
Regards
Gopinath
