Set "Throttle RMAN disk read (MB/Sec)" for Oracle IntelliSnap Backup
  • May 11, 2023
  • 7 replies
  • 249 views
How set "Throttle RMAN disk read (MB/Sec)" parameter for "RMAN Backup Copy" using "Proxy Server" operation?
If I setting "Throttle RMAN disk read (MB/Sec)" for schedule under subclient which using IntelliSNAP it not take effect.
Best answer by MianMajid
Can you please open a Support Request and share that SR number, I will investigate it.
  • May 13, 2023
Please change the value of this PARAMETER under the sub-Client of Proxy Host.
We use cluster group client for source and proxy clients. Also this PARAMETER change on schedule or scheduler policy but we dont have schedule or scheduler policy under the sub-Client of Proxy Host.
  • May 15, 2023
Please try it on the Cluster Client Group of the Proxy. It is sub-client level parameter. You do not need to add it under the Schedule or Schedule Policy.
 I can’t find this parameter in Sublient porperties tabs
 but it located on Oracle Options tab when i run backup or create schedule for subclient
I also set an additional parameter nORA_BKP_RMAN_RATE_IN_MB at the client computer level for both Cluster Client Group members, but this also does not affect the ALLOCATE CHANNEL command.
  • May 16, 2023
Sorry we don't have a support contract at the moment..
  • July 28, 2026
Hi ​@Evgeny.Piskunov , please note that we cannot directly open a support request with Oracle on customer’s behalf but can work Oracle support if customer has a complaint/Support request where Commvault is involved.
