Set Up Connectivity Between On-Premises Proxies and the Azure SQL Database Managed Instance
  • Jul 5, 2024 10:06 AM UTC
  • 92 views
I m trying to set up an on-premises connection to Azure SQL Managed Instance using documentation from Commvault. However, the link provided in their documentation seems to be unavailable. Could you please suggest an alternative Microsoft link or resource that I can use to establish this connection?
https://documentation.commvault.com/11.24/essential/set_up_connectivity_between_on_premises_proxies_and_azure_sql_database_managed_instance.html
Hello @Rupankan Bhowmik
The documentation does state that S2S is a requirement. I do not know of any other way to achieve this.
Kind regards
Albert Williams
This section of MS doco goes over a number of different network scenarios that may be applicable for your environment:
https://learn.microsoft.com/en-us/azure/vpn-gateway/tutorial-site-to-site-portal?toc=%2Fazure%2Fvirtual-network%2Ftoc.json
Kind regards
Albert Williams
Hi @Albert Williams
Do we have any other methodology than S2S VPN connection/site to connect and backup Azure SQLMI ?
Kind regards
Albert Williams
Hi @Albert Williams  After testing with a third-party application like Veeam  I found that it worked without requiring server-to-server (S2S) connectivity. Could you please verify if your software employs a different methodology to achieve similar functionality again?
Thank you.
