I m trying to set up an on-premises connection to Azure SQL Managed Instance using documentation from Commvault. However, the link provided in their documentation seems to be unavailable. Could you please suggest an alternative Microsoft link or resource that I can use to establish this connection?
Set Up Connectivity Between On-Premises Proxies and the Azure SQL Database Managed Instance
Hello
The documentation does state that S2S is a requirement. I do not know of any other way to achieve this.
Kind regards
Albert Williams
