SQL 2012 Components on 11.30 install
Forum|alt.badge.img+9
I have a Production CommCell where I did a hardware refresh from Win 2012 v11.24 to Win 2019 v11.30
On the new VM I notice in add/remove programs that I have SQL 2012 components also installed.
I also checked the CommCell in my Test Lab and its a brand new v11.28 install and it also has the same SQL 2012 components installed.
As SQL 2012 is no longer supported can these be removed ? plus why are these SQL 2012 components getting installed.
Best answer by Chris Hollis
@atitagain
Confirmed it's safe to remove 2012 SMO and native client in FR28 and FR30.
We will no longer install these apps in FR36+ (by default).
Thanks for your patience getting this reviewed, lots of testing involved!
Regards
Chris
Chris Hollis
Hi @atitagain
Our documentation site lists these components as third party apps to be installed - https://documentation.commvault.com/2023/expert/third_party_applications_installed_by_commvault_installer.html
So as they are listed, they must be required for functionality.
I’ll see if I can find out specifically why these are necessary given that 2012 is now deprecated.
Chris
  • Byte
  • 53 replies
  • January 12, 2024
@Chris Hollis , thanks for your reply.
Chris Hollis
@atitagain
I spoke to my development team, they’re investigating and will alert me by next week as to why and what the future plans are.
Chris
  • Byte
  • 53 replies
  • January 17, 2024
Thanks Chris,
I have security scans picking up SQL 2012 and that is raising alarms
Chris Hollis
@atitagain
Thanks for your patience.
Received confirmation SQL 2012 SMO and Native client are no longer necessary and are marked deprecated in FR36+.
However, I’m just seeking confirmation one last time that they can be removed on FR30/FR32 and FR34 setups.
Will hopefully get this clarified overnight.
Chris
  • Byte
  • 53 replies
  • January 25, 2024
Thanks again Chris
Chris Hollis
  • 333 replies
  • January 25, 2024
@atitagain
Regards
Chris
  • Byte
  • 53 replies
  • January 25, 2024
Thanks Chris, have a few CommServes to visit now to remove SQL 2012 component's.
Cookie policy
Cookie settings
