SQL Always ON Transaction Log issue ( Log Shrink )
  • May 17, 2024 3:18 PM UTC
  • 463 views
Forum|alt.badge.img+5
Sql always on Full backup being taken from primary server but  log backup being taken  from standby server at every 15 minutes .Job finished succesfully  but.
This  causes problems in log shrink and sql log folder overgrowing
How do I ensure that the log backup is taken from the Primary SQL. server
Best answer by Sunil
This backup preference can be configured from SQL side.
In SQL management studio, open AG properties and set backup preference. We use the preference set here to run backups. If you set this to Primary, the log backups also will run from the Primary replica.
Please try this and let us know how it goes.
Sunil-
Sunil
Forum|alt.badge.img+16
  • May 17, 2024 3:42 PM UTC
Hi @BillyBoo
You can set the primary replica as the preferred for running backups. This will force the log backups to run on the primary replica.
Sunil-
  • May 17, 2024 3:46 PM UTC
Hİ @Sunil
How can i do that. full backup taken from primary  but log is taken by secondary .i want to take log backup from primary
on configuration tab 1 is already set primary
Sunil
  • May 17, 2024 4:08 PM UTC
Sunil-
  • May 17, 2024 4:21 PM UTC
Hi @Sunil
after that change i saw sql log backup on Management studio.thank you taken from primary 😀
but Log folder size stil same  ( not shrink )
do i need any setting for log  folder  shrink size ?
Sunil
  • May 17, 2024 4:26 PM UTC
We do truncate the logs as long as the option “Do Not Truncate Log” is not selected. However, I’m not sure if there is a delay from SQL side to free up the space. It may still reserve the log file space though it’s free.
Sunil-
  • May 17, 2024 4:28 PM UTC
thank you @Sunil  i will monitor the system we will see.
